Samples on channel 4:
With Djay pro the button “ASSIGN to 4” is not working below the “Sampler level” knob.
With serato it works fine.
If it would work, you can add some h/w effects to the samples.
Can you update this?
Hi @Sneakdiver, can you please share some short videos of how this currently works in djay and how it works in Serato? I want to make sure I fully understand you suggestion before sharing it with the devs. Thanks!
Here is how it works in Djay pro. No assignment to channel 4.
Here is how it works in Serato pro. you can assign to channel 4.
Thanks for the videos @Sneakdiver. This really clarifies things.
