- Hardware firmware version (e.g. 1.0.1):
- Please consider sharing a short video or screenshots to help clarify your question/suggestion/feedback
- anyone usinng the Rane Performer and having issues with holding down shift to adjust the pitch slider to reset BPM but BPM is still changing, this was not like this before, I am using MAC Air M4, with latest 26.xx, any suggestions? Oviousy am using the latest version of DJ Pro.
Hi @djspinster23, welcome to the Community! Are you 100% sure this was working in Algoriddim djay on a previous version? I’m pretty sure that djay has never supported this on the PERFORMER or any DJ hardware. In djay the tempo fader goes straight to the deck’s tempo, and holding SHIFT doesn’t change what the fader does, so the BPM will always follow it. I double checked the MIDI mapping file for the Performer and confirmed there is no functionality like this mapped to SHIFT+Tempo Fader.
Using SHIFT to move the tempo fader without changing the tempo is a Serato DJ Pro feature on this controller. Rane’s Serato quick start guide lists it as “Ignore tempo/pitch adjustment.” If you’ve used the PERFORMER with Serato, that’s probably where you remember it from. I hope that helps!
It hasnt been this way on algorridim Djay pro its works like that on serato but its actually a good feature to make shifting tempo a bit faster
