Rane Twelve MkII Cue Points move with Sync
I use a MacBook Pro (M1 Pro) and a DJM S11, and I use DJ Pro with either Vinyl or the Rane Twelve MkII.
I’m having a big problem with the Rane Twelve MkII.
If I enable Sync (BPM and Beats), the cue points constantly move.
When Sync is disabled or set to “BPM only,” the cue points don’t move. This also happens with Vinyl, but to a lesser extent and you can still play, but with the Rane, the cue points constantly move. Help
Device Model ( MacBook Pro - M1 Pro ):
Version of operating system ( Sequoia 15.7.1 )
Version of djay ( 5.5.1 )
Hardware/controllers used ( DJM S11, Rane Twelve MKII )
On the Rane Twelve I use the Serato USB Mode and on the Software are imposted on Internal mode.
Hi @BOBTRICK, when creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency. Thanks!
Since this sounds repeatable, can you please capture and share a short video of the issue to help clarify what’s happening? Thanks!
Hi, sorry, I’ve been really busy. If it’s not a problem for you, I’ll send you a video by tomorrow. Thanks for your understanding.
Sounds good. Thanks for the follow up @BOBTRICK. We can revisit this tomorrow or when you have time to upload the video.
