Recent experience / advice on FLX10 / RANE Four / Mixon 8
I’m looking for some recent user experiences and advice with these controllers on djay Pro, given that djay has changed quite a bit since when these were released initially (e.g. FLX10 jog wheel displays). I’m a Windows user.
I’ve watched several YouTube reviews, but they mostly cover performance with Rekordbox and Serato, except for the Mixon 8, of course. Overall, the controllers all seem great in principle:
  • The Mixon 8 is the cheapest of the three.
  • The FLX‑10 is a couple hundred dollars cheaper than the Rane Four.
  • The Mixon 8 meets my needs fundamentally and is significantly cheaper, though I’m concerned about reported quality issues. All of these controllers represent a substantial investment.
Mixon 8:
  • least worried here, naturally, about software compatibility. Any negatives that are particularly standing out.
  • how bad is the visibility of the caps of the mixer section in the dark really?
FLX‑10 questions
  • How well are the jog‑wheel screens supported now?
  • When selecting pad modes, presumably djay pro does not show the assigned pad values automatically, like with other controllers?
  • If not, does the jog‑wheel screen preview work in djay Pro?
  • Are sound‑color/channel fx and hardware effects properly supported in djay Pro?
  • Does stem handling, including applying effects to stems only and sending stems to the other deck, work well and as expected?
  • Any major limitations with djay pro?
Rane Four questions
  • Does stem splitting to channels (e.g., 1/3) function correctly?
  • Are there any stem‑related features that don’t work as expected?
  • How well do the jog‑wheel displays work with djay pro?
  • The four channel‑FX filters appear to be software effects; are they supported in djay Pro?
  • Do hardware effects integrate smoothly with djay Pro?
  • Regarding pad displays: are hot‑cue names shown and assigned values in the various pad modes?
  • Is the combination of pad modes supported properly?
  • Are there any other features that don’t work as expected?
Big purchase decision, so I’m happy to learn what djay pro users are not happy about. Fundamentally, I think these are all capable controllers in principle, I think it’s really mostly about how well the integration with djay pro is.
Chris
I can’t give you an answer but I’ll be keeping an eye on this thread as I’d also love to know the feedback on this question.
Hi @Chris13, I only have personal experience with the Mixon 8 Pro, but I can share some info that might be helpful for the others
Here’s where things stand on Windows (current version 5.6.9):
DDJ-FLX10
  • Jog wheel screens have been fully supported on Windows since djay 5.4. The only screen exception on our compatibility list is iOS.
  • djay’s on-screen pads don’t switch to follow the FLX10’s pad mode buttons. What you do get is PAD INFO (added in 5.5). Hold PAGE in Hot Cue mode and the jog screen shows each pad’s cue color. It shows colors only, with no loop icon for cue loops.
  • Sound Color FX and Beat FX both work. The Sound Color FX lineup is fixed, and wet/dry resets to a set level each time you switch one on. The COLOR knob is your hands-on control for how hard it hits.
  • For stems, the ACTIVE PART buttons and EQs control Neural Mix, and FX Part Select works per stem. Two things to know:
    • Part Instant Doubles sends the stem to the deck on the same side (1 to 3, 2 to 4), so you need the Four Decks view.
    • Post-fader FX aren’t supported on Neural Mix parts. An echo on vocals only won’t tail out when you cut the fader.
RANE FOUR
  • It runs as an external mixer mode device. EQs, faders and the crossfader are handled in the hardware, so they don’t move on screen. The four channel FX are part of the FOUR’s internal FX engine, so they’re processed in the hardware too.
  • Jog displays are supported, but the deck 1/2/3/4 indicator doesn’t change when you switch decks.
  • STEM SPLIT works, but there’s a known audible delay when you engage it on a playing deck. Engaging it before the track starts avoids it.
  • Software FX have some limits:
    • Only 1/16 to 8 beat intervals are selectable from the hardware.
    • Decks 1/3 and 2/4 share FX.
    • Post-fader FX only engage when triggered from the hardware paddles. Setting FX to Pre-Fader in Settings > Sound works around that one.
  • Sampler-to-deck-4 isn’t supported. I can’t confirm hot cue names on the pad OLEDs or how Combo pad mode behaves, so hopefully a FOUR owner can jump in there.
MiIXON 8 PRO
  • It was developed with Algoriddim and is natively supported, including jog displays, Paddle FX and Neural Mix control from the EQs.
  • It’s an Internal Mixer Mode device so doesn’t have some of the limitations of the RANE Four.
  • I always swap my caps for DJ TechTools Chroma Caps so I can really speak to the visibility of the stock caps in a dark booth.
  • For me the build quality wasn’t an issue. I was an early adopter and didn’t expertise jogwheel issue that some early units had.
Whichever way you go, I’d buy from somewhere with a decent return window so you can put it through its paces with your own library. I hope that helps!
Thanks a lot Slack_Jaw, most helpful!
The Rane Four is now out of production/discontinued and judging by Reloop’s interest in the controller market latlely the Mixon 8 can’t be far off. The FLX10 represents the best long term investment imo.
Hi Daniel,
Yes, I tend to agree. I have the feeling that with the large user base and also given the price point, the FLX10 may be more advantageous. Also, I guess the internal mixer architecture may ultimately be more advantageous over the Rane four too.
In terms of other lower cost options, there’s also the REV5, but I am not into scratching. However, the way the REV5 deals with stems is quite similar to the Rane four. Another nice one is that the power supply is USB and two computers can be hooked up, something the GRV6 can’t do. Quite a nice and tidy unit.
Thanks for your input
What is the intended use for the new device? If you are pro/mobile then I would go with with the FLX10 or similar build quality. If you are just stepping up from a cheaper controller the REV5 would be more than ample.
The main use is bring-your-own-gear club events, the odd mobile dj gig. Build quality is certainly a factor but at that price difference, maybe slightly less so. As far as the electronics goes, it’s all good these days.
Its mad how slimmed down the controller market is now isn’t it. I agree the FLX-10 offers the best overall package, definitely a cool unit.
You’re welcome @Chris13. Happy to help!
Mixon 8 is an excellent controller for DJAY Pro. You can really customise your own mapping. And yes change the caps for dark environment (actually the Reloop caps in color make the trick). Except some sticky pad at the beginning I have never faced specific issues.
Thanks for sharing @Djay_Fleg
