The user guide suggested that you can run DJ Pro on any Mac running OS 10.9 or higher. However I run older version of DJ on a Mac with 2.33 Ghz Core 2 Duo and 3 GM SDRAM and I experience screen freeze. (OS 10.7.5) I’m looking to buy a new Mac and I’m worried that getting on with less than a 2 GHz processor will cause issues. What are the recommended best processor speeds and RAM?
Hey Brent,
the macOS version 10.9 is only supporting certain Mac’s which are all working flawlessly with djay Pro for Mac. Therefore, we dont have another requirement than the macOS version.
Cheers,Lukas E.
