Recording disapeared
After doing a 90 min recording I renamed it and exported to itunes and it exported 48 secs only…it appears to have not recorded? When I stopped the recording it showed 90 mins on the timer…
can you please tell us which djay version you are using?
Also is it possible that you accidentally stopped the recording, are you using a lot of keyboard shortcuts?
