I have a reloop beatpad with ipad and djay 2
Im thinking of updgrading to a mac and djay pro but i have a question … How does it work with a 2 deck controller? Am i able to switch from the software which channel is on the deck?
You will be able to control 2 Decks using the Reloop Beatpad (Deck 1 and 2). It won’t let you switch between several Decks.
In order to get this working, you’d have to map one of the Beatpads to Decks 3 and 4. However, it will get very confusing having 2 mixers…
Just a thought … How about if i add a second beatpad? Will i be able to switch it to control decks 3 and 4?
