Ok just about to invest the money in reloops beatpad2 ,it’s a lot of dosh but looks like. So much fun,I’d like to know what other uses think of it ,Is it worth the money ,good and points thanks
I have the beatpad 2. It’s a great controller particularly if your looking to play with Djay. The layout works so well with the software, very intuitive. I love the pads with 8 cues and effects as you can use preset effects or set your own jog effects where you can set two at a time, a lot of fun.
The only negative I am experiencing is you can only set the loop to 8 bars using the beatpad 2 pads. I’ve asked for this and others have to be extended. Will they do it? I doubt it.
Overall I love it.
