reloop interface edition 2 shift key mapping
Hello everybody
The most key’s/button’s work’s on the reloop ie2 controller but “the shift button” does’t match with the djay app. have you any idea where I could handle this?
on the midi config I found it but I don’t know how to match the shift function. the mapping for this hardware key is empty.
Thank you for your answers.
Cheers
Manuel
Hi Manuel,
Generally you don’t map the SHIFT button itself but rather SHIFT + some other button. In the configuration window, try pressing another button while holding down shift.
Hello
Thank’s for your answer. Ok and how can I use the filter function on the “high key”?
