I can’t get my Reloop Terminal Mix 8 mapped properly. Any other TM8 users out there who have tacled this problem and want to share their .djayMidiMapping file?
It would make 1 noob incredibly happy.
Do you have any specific problems on that? Maybe I can assist you…
Great work, Dimitris! We would love to have the mapping, as well. You can sent it directly to “adrian@algoriddim.com”.
Not working:
I would love to use the mapping file Dimitri! Could you upload it somewhere?
Dimitris, I would love to have the mapping file! Could you upload it somewhere?
Thanks Dimitris!
Have you managed to fix that? If yes can you share the configuration file?
I have finished the mapping with Terminal Mix8 . If you are interested I can share.
@Adrian. I have not faced the issues that Cornelis describes. I am using the latest firmware for Terminal Mix8 and Sync , Multiple decks and LEDs are working except the following minor issues:
No problem, I am glad to help if you have any issues.
I dont know if you have upgraded the Terminal Mix8 to the latest version this video is helpful to for this controller : https://www.youtube.com/watch?v=9ZeTm…
Hello Gerry. Nice to hear that someone using my shared mapping file. I dont rememeber if in the last mapping file I have added the proper jog pitching. Check it out and let me know.
Also i have added some features with the ctrl button. For example you can change the FX sounds using CTRL+FX
I spent a lot of days testing it out…so yes it needed some work.
Hi Dimitris, I just bought the Terminal 8 today. I used your mapping file for Djay Pro on Mac and it looks all good. Most functions are good. Im going to use it on a live gig tomorrow night, see how it goes. Thanks for sharing the file, must have been hard work
