Remove played tracks does not work unless you are “autoplaying” in the queue.
Not sure if this is by design or not but wanted you to be aware.
Looking into it, I found out:
Checkmark and removal from Queue won’t work out if the song is startet AFTER the Crossfader is switched over. I guess this is what you mean with “unless you are autoplaying”, Scott.
Keep up the good work, guys! We are already working on the fix!
It is the same for the “already played” checkmark. I don’t know if this is related.
I can’t wait to test the new version.
