- MacBook Pro M1 Max*:
- macos 15.3.2 *
- Version of djay 5.2.9:
- Pioneer DDJ SX2*:
I’m using SHIFT + CUE (Deck) to switch the EQs to Neural Mix Mode. Is it possible to reset the EQs to normal EQ Mode when loading a new Track to a Deck? I tried to solve it with a Mapping on the Load-Button, but the Eq-Modes use a toggle button. Or can i set it to a specific state?
Thx for your help.
Thomas
Hi @tom_tyron, welcome to the Community! There is no setting to return NM EQs to Normal EQs when loading a song to a Deck. I don’t think you’ll be able to achieve this via MIDI mapping either as the only available Advanced Control Configuration options for the Button Mode mappings are “Default”, “Toggle” and “Hold”.
Hey @Slak_Jaw that’s a shame, but thanks a lot for the info. Maybe it could be added as an option in the reset function in the settings at some point.
You’re welcome @tom_tyron. I’ve changed this topic from a Question to a Suggestion. Please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
