Good afternoon, I have a parent Hercules RMX2 gold, I can use the Pro djay with it and get all the Pro djay resources through it?
Today I have the djay2 with mapping and camera connection kit, but not with all features.
Is there a way to test before buying as the Mac version?
I am to get a Mac, I have to buy the Pro djay separately?
Grateful.
thank you for your post.
Please note that the RMX2 is not supported by the djay Pro version for iOS but it is natively supported by the Mac version.
If you get the Mac version I am sorry to tell you that you have to buy the version separately.
To check which controllers are supported by which djay version, check here.
Cheers,Lukas E.
