Good afternoon. There is a problem with displaying Russian fonts. When renaming the comments column in the application, the Russian text is displayed normally, but when you re-enter the application, the encoding is lost.
Application version 5.3.1
Hi @mr.digson, welcome to the Community! Sorry to hear you’re experiencing this issue.
- What Mac hardware and macOS version are you using?
- Can you please try to capture a short video of the issue and upload it here?
MacBook Pro m1
Sequoia 15.4.1
«An error occurred: Sorry, new users can only put one embedded media item in a post.»
I get this message when I try to attach an image to an answer.
Hi @mr.digson, I have manually changed your Trust Level from New User to Basic User. You should be able to share your video now.
You’re welcome @mr.digson. Thanks for the screenshots.
Hi again @mr.digson, could you please check the ID3 tag of the file after you edit the comment to see what the contents is? You can use an app like https://kid3.kde.org/ to do this. Thanks!
Thanks! Can you tell me which id3 tags are most preferred for the application?
@mr.digson I’m not exactly sure what you are asking, but djay reads the most common ID3 tags e.g. title/artist/genre/comments. Could you please send an example file they are trying to change the comments on, and also some example text that triggers it and then we can try and reproduce?
