Hello in my window app, I cant create custom saples in samler od add one as seen in video I press record and it it white and no recording samples.
Can anynone help me please.
Hi @DJ_MKB, thanks for the video. When creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency. Thanks!
%HOMEPATH%\Music\)?%HOMEPATH%\Music\djay Media Library\Samples\ do you see any sample recordings in this folder?Yes and folder is empy. Throu my mobile phone it is working. Im windows 11 user.
Thanks for the additional info @DJ_MKB. Please provide specific details for your setup so we can try to reproduce this on end.
Device Model Notebook HP
Version of operating system (Windows 11 Home 26200.8246):
Version of djay (5.6.4):
Hardware/controllers used (Gemini slate 4 - cutom mapping):
Thanks @DJ_MKB. Do you experience the same issue without the Gemini Slate 4 connected to your laptop?
No there is no issue with controller, problem is reccording my samples or adding mp3 files to sampler
I understand, but does the issue still occur when your controller is disconnected?
Yes video was done with controller unpluged.
Great. Thanks for clarifying. I was unable to reproduce this on my Windows device so I need pass this onto our engineering team for further review. I’ll report back when I have more news.
So on your windows device it is recording samples? If yes I will try prodjay on another devicew
Yes, Sample Recording is working properly on my Windows device.
Problem solved - Avast was protecting Djay Pro music folder.
Problem solved.
Good to hear. Thanks for the follow up @DJ_MKB
