Sample Volume Knob Ignores Position on Restart
“When a knob is assigned to control the volume of a single sample, for example ‘Right sample sample volume 4’, the control adjusts the volume until the end of the sample. If the sample is restarted, it will play ignoring the knob’s position.
Can this be solved?”
device: Macbook pro all version
Device: Windows 11 and Windows 10
Controller: Pioneer DDJ RX
Controller: Traktor Kontrol X1
“If you want to replicate the bug, simply assign any control via MIDI to the single track volume of the sampler. Play, for example, ‘Right sample sample volume 4’, decrease the volume of ‘Right sample sample volume 4’ with the assigned MIDI control. Wait for the sample to finish, and without touching the control, restart the sample. It will start playing again, ignoring the volume set with the MIDI control.”
best regards
Gianni
Hi @Gianni_Notarnicola, good catch! The team was able to replicate this and it looking into it further. I’ll report back here when I have more news. Thanks!
Good morning, are solved with 5.3.1 update?
Good morning @Gianni_Notarnicola. Thanks for checking in. The team is still working on this one so, no, this is not addressed in 5.3.1.
