Please clarify for me, what is the MIDI command for saving loop. Can’t get the logic behind it.
I see only Activate, Reloop and Clear, but not the initial Save Loop
Thank you
Thank you
Hi @Mikhail_Kapyrin,
Thanks for your question!
You can only save a loop, if there is a loop active. Otherwise, there is nothing to save. If no loop is active, it’s not possible to save a loop.
Once you activated a loop, you can save it by pressing the “Save Loop Activate” button for one of the 8 saved loop slots. If you press the activate button of a slot that is already taken, it will activate the respective loop, but it won’t jump to its position.
You can jump to a saved loop with the “Saved Loop Reloop” button. And you can remove a saved loop with the “Clear Saved Loop” button.
Did this solve your question by any chance?
