Is there a way of saving the settings of the 31/10 band or the parametric equalisers? It seems they go away as soon as the EQ HUDs are closed. I’d love to be able to save some tried and tested settings, rather than having to write them down and re-adjust them every time.
These settings cannot be saved. I’m honestly not sure if this is even technically possible but I’ll pass it on to our developers.
Any update on this matter??
Has it been fixed?
Was messing up my set having to re-adjust each time
