Hi, it seems to be perfectly possible to search in my library using “contains” strings for genre (I use itunes genre definition, which is a space separated field, f.e. “disco smooth funky”) but when I want to create a smart playlist (or want to filter) I cannot do this, as it makes unique strings of all entries in the genre field, why is this limitation?
Hi @olafmol, thanks for laying that out so clearly. You’ve read it right. In smart playlists and the filter bar, the Genre rule is a pick-list of the exact values in your Genre field, so “disco smooth funky” counts as one genre, not three. Contains does work on text fields like Grouping and Comments, so the easiest fix today is to build the rule there:
- Copy your genre tags into Grouping (or Comments) in Music or your tag editor.
- In djay, go to My Collection > + > Add Smart playlist.
- Click + and set the rule to Grouping > contains > funky.
There’s already a suggestion for a “contains” option on Genre, so feel free to add your vote here: "Contains" filter for smart playlists
I hope that helps!
