Second XDJ 1000MK2 player won't function
Your question:
Hello the following problem:
I have the Pioneer 750MK2 mixer and the Reloop RMX-95 both connected but the second player is not recognized by Djay PRO. What could be the reason for this?
The setup I want to use is:
Reloop RMX95 Mixer v1.01
2 x Pioneer XDJ 1000MK2 Player firmware 1.4
HP OMEN Laptop
Windows 11 64Bit Pro 24H2
Djay PRO 5.3.3033.0
The laptop is connected with USB to the USB port of the Reloop mixer in USB-B.
The XDJ players are both connected to the laptop via USB.
Djay PRO ASIO Reloop selected for audio source
Deck 1 XDJ has a mapping and I can also use this in Djay PRO and control and navigate everything normally with it. The player is on “LINK” and in the display I see USB connected and I can use it as mentioned in Djay PRO.
Player two is on deck 2, it is also set to “LINK” and the display shows USB connected.
However, if I want to select a different track with the selection wheel, for example, the Djay PRO simply does not respond. As if the player was not connected.
The patch cable was once connected and then I disconnected it and neither helped.
So how can I set it so that I can work with both players on deck 1 and deck 2?
Thank you
Hi @daniel_82, welcome to the Community! Please note that the Pioneer DJ XDJ-1000MK2 is not supported for djay on Windows: DJ Controllers, DJ Mixers and other DJ Accessories | Algoriddim
