"Select Playlist" in Automix not disappearing after selecting a playlist
  • Device model : iPad before M1
  • Version of operating system : IOS : 16.7.10
  • Version of djay : 5.2.4
  • Hardware/controllers used : Not controller related
“Select Playlist” not disappearing after choosing a playlist for Automix on iPad.
When selecting a playlist as source for Automix on iPad (here I chose “Violeta 50”, the “Select Playlist” button remains hanging (bottom right corner), and there is no way to remote it. This “Select Playlist” button does not belong there in the first place as “Select Playlist” appears when called from the down arrow choice for (“Queue” or “Playlist”). But after choosing a playlist, it appears and stays in the bottom right corner. Which is a bit annoying as screen estate is already scarce. This is a probably an easy bug to fix.
Illustration
(see bottom right corner).
Thank you
Hi @Davidv100, thanks the details about your setup, the issue and the screenshot. This is very helpful! I was able to replicate this and have passed it onto our dev team for further review. I’ll report back when I have news. Thanks!
Hi @Davidv100, I spoke with our engineering team and this is by design, as users had problems figuring out how to select playlists. Thanks!
Ok, Thanks - I think it is a waste of precious screen estate. But of course I respect the design.
Thanks.
You’re welcome @Davidv100
But, just to be clear though… the two tools I squared in green lead to exactly the same thing… when we have so little space to start with…
You see how much is space is wasted there.
