After the great release with options to use Neural Mix Crossfaders (and the lack of multiple crossfaders on most controllers):
Wouldn ´t it be nice to map the Neural Mix Crossfaders to the EQ knobs (as already the „N“ option on the Mixtour Pro has) via „Shift“ + High/Mid/Low?
Of course it´ s already possible to map them to deck 3/4 on 4 deck controllers, but when switching you loose control of deck 1/2 and have to remember to turn back.
Thanks for the suggestion @Riff. I believe this would require a firmware update from Reloop as this Mixtour Pro does not currently send difference MIDI messages for the EQs when holding SHIFT. I have forwarded this to the dev team for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
