Show BPM Change
When there is a BPM change, reflect BPM numbers in the display.
Hi @gizmo, we already show the change in BPM values on the large waveform and on the BPM display.
I’m guessing you also want these numbers displayed on the overview waveform as well? If so, how would you like this shown? Maybe you can markup a screenshot to illustrate? Thanks!
Good call out, thanks Slak_Jaw!
The request is to show numbers in the overview as well. When the library is expanded, solely the overview is visible.
When trying to find songs that fit the mix, DJs can anticipate a BPM change more easily, by seeing these numbers for which songs would and would not mix well.
You’re welcome! There isn’t much room on the overview waveform. How exactly do you think it should be displayed @gizmo?
A tough one given small real estate area.
This feels appropriate for the use case @Slak_Jaw .
Perfect! This is exactly what I was looking for. Thanks @gizmo. I’ll pass this onto our devs for consideration.
this would add clutter, really. the info is already present - i think it’s smart the way it is.
the only improvement i ask of them is that sometime the change markers are gone (setting is ON)
what’s the proportion of your library with these kinds of tracks?
Thanks for the additional feedback @Armigo
Significant portion. A lot of music recorded before computers.
