I think it would be a great option for an option to turn slip mode on permanently via settings.
It’s a pain having to it for each track with the current set up.
Hello Lukas
Thanks for the response.
Surely an option in the main settings would give me a choice so that way we can all get what we want?
Cheers
thank you for your feedback.
We decided to reset the Slip mode after inserting a new track because if you activate it by accident the option is a bit hard to find.
I hope you understand.
Hi GISCO,
thank you for your follow up.
I forwarded your request internally, thank you for that.
It would be great if other users which are feeling the same would upvote this thread in order to push the issue.
