I use 1.0.26524.0 spotify version since a while the song I found and try to use in spotify play but no sound at all. I’m on windows 10 and all update are done. I’m using a lot automix and my playlist is build with hard drive and spotify song. Every time the song switch from a hard drive to spotify song I have no sound. Will you please have any hint to fix that problem.
thanks
