Sorting by BPM mixes x1 and x2 values
Hi again @David_Bielby you’re right, your screenshot shows the filter is using your doubled values (160 and 170 both make it into the 140–199 range), but the sort is still ordering them as if they were 80 and 85. I’ll add your screenshots to the existing report.
Until it’s fixed, a BPM filter is the reliable way to group these tracks by tempo.
On the re-analysis, one quick check: after you ran Analyze Songs on those tracks, did they come back at 160/170 by themselves, or did they drop to 80/85 and you had to tap x2 again? Thanks!
