Sound fx button broke
IDjpro but it still doesn’t work when using just the iPad. I’m talking about the button under the record button that opens up the beatpad and custom sound fx
Yes. I got it to work but it will only work if you switch the decks to 2-view mode when the iPad is turned sideways. If you are in 4-deck mode, then the 9 dot sampler button will not work. Maybe a bug. Thanks
are you using an external controller besides your iPad?
Are you referring to the 9 dotted sampler icon? Have you tried adjusting the sampler volume?
Hi Craig Walter,
i see, in 4 deck mode excluded the sampler due to design decisions, i hope you understand.
