Is there anyway of using sound spectrum visualizers with DJay? I’m using it with two monitors, and displaying some audio visualisation on the second one would be great.
This is currently not supported but I’ll change your question into an idea.
I believe this is possible with Soundflower (free from cycling74) or WireTap Anywhere ($129 Ambrosia software). Assuming you’re running the standalone sound spectrum software, either of these utilities provide an audio input to g-force (I assume other sound spectrum software uses a similar input scheme).
