Hi Everyone
I just bought the Djay App for my MAC Book and now I’m searching for a good splitter cable. Can anyone give me a good suggestion? There are so many different sound cards and cables available.
Tom
Hi Everyone
Tom
Hi Tom,
On the Mac, I definitely recommend getting a USB sound card instead of a split cable for better sound quality.
If you’re looking for an affordable USB sound card, check out Griffin imixhttp://www.algoriddim.com/hardware#imic
Generally speaking, you can use any external audio interface that is supported by the Mac.
Hi Warren,
Thanks a lot for your answer, I just ordered the iMic from Griffin.
Best regards
