Spotify catalog search returns "No Results" on iPad (playlis
• Devices: iPad Pro 12.9-inch (3rd generation), plus my son’s iPad (both affected)
• iPadOS version: 26.6.2
• djay version: 5.6.9
• Hardware/controllers: none
• Spotify: Premium, Family plan (both affected users on the same plan)
A) SUMMARY
On Oct 7, 2026 at about 4:00 pm Pacific, Spotify search inside djay stopped returning anything from the Spotify catalog. It only finds tracks already in my own playlists. My playlists and Liked Songs still load and play normally. It broke at the same moment on my iPad and my son’s iPad, both on the same Spotify Family plan. The two iPads were in different locations on different internet connections when it broke, so it isn’t a network issue. Search worked normally the day before.
B) STEPS TO REPRODUCE
  1. Open the Spotify library in djay
  2. Tap search and select the Spotify side of the toggle (not the playlist side)
  3. Search any artist not in my playlists, e.g. “Riff Raff”
C) EXPECTED
Results from the full Spotify catalog.
D) ACTUAL
“No Results.” Searching with the playlist side selected works.
E) ALREADY TRIED
• Logged out of Spotify in djay, closed djay, restarted the iPad, logged back in
• Removed both djay connections under Manage apps on spotify.com, logged out of the Spotify app, restarted, logged in only through djay and approved access again
• Force-closed and reopened djay
None of these fixed it. Search in the regular Spotify app works fine.
Also noticed: the Spotify icon on the search toggle shows gray, not green. Not sure whether that’s normal.
Hi @Mike_Card, welcome to the Community! There was a temporary issue on the backend which should now be fixed. Please test again and let me know if you’re still having this issue. Thanks!
