Spotify pinned playlist limitation
Hi there, hopefully someone (probably @Slak_Jaw lol) will be able to find out: is it a Spotify limitation that we can only pin one playlist, or is it possible to give us the ability to pin more?
Cheers!
Hi @Digital_Self, you can pin up to 4 playlists. That limit is applied on Spotify’s side.
Well thanks for this, I unpinned my Liked tracks, and now i have the option to right click and pin others. Before when my Liked was pinned (which im pretty sure was by default) right clicking others only showed a delete option. However there are still some that won’t let me pin.
You’re welcome @Digital_Self. Thanks for the additional info.
Hi again @Digital_Self, actually a correction here, Spotify may have removed the 4 playlist pin limit recently as we tried it in the app and can now pin more playlists.
For the playlists that don’t have the pin option do they live in playlist folders in the main Spotify app? I think you can only pin top level playlists.
