Spotify to Folders
It would be good to have folders for playlist like in spotify.
You can great folders like:
House
→ Playlist x
Playlist xx
Playlist xxx
Rap
→ Playslist x
→ Playlist xx
→ Playlist xxx
Dance Chart
→ Playlist x
→ Playlist xx
→ Playlist xxx
ETC
ETC
ETC
thank you for your post.
Unfortunately at the moment the folders are not supported by the Spotify api.
“Folders Folders are not returned through the Web API at the moment, nor can be created using it.”
Source: https://developer.spotify.com/web-api/working-with-playlists/
We will keep you updated if there are news.
