When using beatpad 2 or mixtour controller with iPad Air 2 and when l’m previewing a track from Spotify app crashes when I use track navigation.
This happens with both djay2 2.8.5 and djay Pro 1.0.5 apps.
Same here, exactly the same problem and when are they going to fix shift + que
i’m using Djay pro+Reloop beatpad 2+ Ipad Air 2
djay Pro New 1.0.6 update doesn’t seem to fix the prodlem.
Version 1.0.4 is the one that is stable and not buggy! If you can manage to downgrade the app
PLEASE FIX THIS PROBLEM!!!
