Is anyone experiencing stability problems with Djay 2 on ios7? The sound frequently glitches and it takes about 7 seconds for a playlist with only 40 tracks in it to load, every time. All my other apps are shut. I’m using a 3rd gen iPad.
Thread initiator, here: I’ve downloaded DJay’s update issued today and the problems I reported appear to be solved. Thank you, DJay people!
I’m experiencing Major track loading issues with DJay 2 in iOS 7 on my iPad 2…
So I think it’s an iTunes issue in iOS 7… I had DJay 2 working perfectly with iOS 6…
After upgrading to iOS 7, I started having all sorts of track cueing issues with DJay 2 on my iPad
Unfortunately, I had to backup my iPad… Completely wipe it clean & reset it, and then restore my iPad & reload and analyze my entire Library…
Lost all the cue points, etc but everything seems to be working fine now…
iTunes itself was acting really buggy on my iPad… Really seems like an Apple OS issue to me though.
