I have a question about auto mix. If I have it set to “use start and end times when available” and also have it set to transition at 12 seconds before the end of the song will it transition 12 seconds before my set stop time in iTunes? Or if that option is checked does it ignore the 12 seconds and just transition at the set stop time? I hope this wan’t too confusing. Thank you!
Hi Bryan,
If available, the end point takes precedence over the other setting.
