Support for local tracks in Spotify is needed - For those of us that built substantial libraries of native sound files within Spotify, it would be helpful to have support for those when using Spotify in Djay. For instance, I have a lot of native tracks that I already had built into literally hundreds of playlists in Spotify and they do not show on playlists in Djay when using those Spotify playlists. As a music bingo DJ, this is wildly frustrating.
Hi @Shane_Bryson, can you please clarify your suggestion? Are you asking for an offline mode/locker for Spotify? Or maybe the ability to have local songs and Spotify songs in the same playlist?
I truly second that, if we are able to play local tracks which are not on any platform it would be great!
Thanks for the input @Tarunsahni1966
Also while mixing on my android S24 WITH THE DJAY PRO MIXER, THE APP CRASHES AFTER PLAYING CONTINUOUSLY FOR MORE THAN 30 MINUTES
Hi @Tarunsahni1966, please make a new topic for this as your comment is unrelated to this discussion. Thank you.
i can probably clarify (correct me if i’m wrong @Shane_Bryson ). In Spotify it’s possible to add local songs to playlists. I guess the OP is requesting that the Spotify integration in DJay Pro also supports loading local songs from Spotify playlists…
Thanks for sharing @olafmol. Please confirm if this is what you are talking about @Shane_Bryson
