Sync option does not work, when dealing with two different ranges
Hi! I’m in love with the djay 2 for iPhone app, however I found something I’m struggling with, concerning the sync option.
Whenever I want to sync a, let’s say, 76BPM track to a 150BPM, it perfectly changes the tempo to 75BPM.
However, when I do it the other way around: I try to sync a, let’s say, 152 BPM track to a 75BPM track, and it changes the tempo from 152BPM to 75BPM, whereas 150BPM would be more suitable.
I think this is a bug in djay 2.
Kind regards,
Sybe
we want to thank you for pointing out this inconsistency. I talked to a developer and we are working on the issue.
Keep on posting your feedback, we really appreciate it.
Any solutions for this problem?
Thanks for the response! I will look forward to seeing the solution implemented in an update!
