Macbook Air M3
Latest MacOS
Latest DJ pro version
DDJ FLX 10 with up to date firmware
Hi guys Im a working mobile DJ with gigs every Friday and Sat night but over the past few weekends I have noticed sync randomly stops syncing the tracks properly and nothing I do other than re booting the sofware will fix it (Which obviously when you have a crowd in front of you is impossible to do). I can manually beat match so thats not a problem but I cant for the life of me work out whats happening. Any ideas?
Hi @R99JDF, thanks for the details about your setup and the issue - this is very helpful! Since this sounds repeatable, can you please capture and share a short video of the issue to help clarify what’s happening? Thanks!
Morning @Slak_Jaw thanks for the reply, no problem I will try to get one this weekend for you. Its really odd because it just randomly happends then won’t re sync any other tracks loaded until I re boot the software. Managed to re boot it during a round of happy birthday on Sat night (nervously!) and it was fine for the rest of the night then.
Hello! It’s been a week since my last reply. I’m going to consider this topic completed for now so I can focus on others. However, please feel free to respond and we can definitely reopen and revisit this. Thanks!
Hi mate. Sorry completely forgot to get back to you. Typically it didnt do it this weekend so I will report back if it happend again. Thanks again for your support spot on as usual.
