In Djay when you hit the sync button and the sync is off beat you can just hit it again a couple of times and it jumps until you’re in sync. Djay pro doesn’t seem to have this feature!?
When you sync tracks and they are off there seems to be nothing else to do than match by ear, or, as suggested in a similar case, put a marker at the start of the track and resync. That’s time consuming and might not do the trick. Could you add/bring back this great feature to Djay pro in a future update? Otherwise I’m sticking to the old, not so pro, djay.
