Synced track returning to original tempo when crossfaded
Hi all
We were playing last night with a mixon 8 and two Mac laptops with Djay
Something really odd started happening. We’d sync a new track and then mix it in - let’s say this was at 112.2 bpm. No problems
Until we’d crossfaded to the new track completely - it would then suddenly jump to its original tempo exactly.
Any ideas why this might be happening? Cant find anything online but also it’s hard to know what to search for.
Your question:
If using crossfader fx, turn off Tempo Blend
Also….
In sync settings change to Sync (you’re on Sync+Tempo Blend)
You beat me to it @Armigo. Thanks!
Great, I’ll give that a go. Thank you!
Hi @Tony123, did that work for you?
