I have created several mixes but sometimes (under certain track combinations), I have the impression that the tempo is not constant when I export the recorded mix as an .aif file. When I hear and replay the exported track several times, there are certain sequences within the recorded mix where the tempo seems going up and down slightly … and it sounds a bit patchy.
Is there a chance to optimize the algorithm to make it sound more harmonious during the entire track?
The algorithm has problems to create a mix using rock music. Even though there is a constant beat, there is no chance to keep both tracks in sync.
Is there a chance to optimize the algorithm to create fluent mixes with different music genres such as rock and hip hop for example.
THANK YOU.
