I was hoping that the new update would have solved the SYNC problems that started with the previous update in April.
This is unfortunately not the case : Sync still does not work after playing a few tracks.
That’s unfortunate, really.
(Lucky I still have Version 1.2.1 which was the best so far…)
Looking forward to the next update then…
Oliver, the new does not address the sync problem but it does update and fix many other things.
It was mentioned that this update will not fix the sync because they are still identifying the underlying issue that is causing it.
Thanks your reply Dj MM. I understand better now.
