Can’t find the way to set FX 3,
I can enable it with my midi controller ( by default it’s set to gate function by the way…)
I’like to change or edit this one
It’s only available via MIDI controller.
You can map one of your knobs or buttons to change FX 3 under “MIDI” > “Configure…”.
Ha ok,
Thanks Warren
Hopefuly All impruvements made for “I devices” will reach the DJAY Macbook world…soon…
