Using DVS in THRU mode allows a user to feed an audio input into a channel. This is useful but having it be part of DVS makes no sense.
The whole point of THRU is that you’re not using DVS. This is problematic because it requires enabling DVS globally (something that cannot be done via MIDI command) just to connect a microphone. While it works, it’s confusing and now all decks have a DVS dropdown whether they’re configured for DVS or not.
INT/THRU should be separate from DVS and configured in the Devices tab.
Thanks for the suggestion @yyz_dj. I’ll share this with our devs for consideration. In the meantime, please use the Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
I do use Thru to get my Ableton Move into Day, so I can use Ableton Link and jam out some of my tracks as part of my DJ set, whilst using my effects and DJ controller setup to get a coherent output together.
It’s not bothered me too much where it is as of now though as I do use DVS. But it would be good if it was separate I think. It’d be cleaner/clearer if I could just use one of the 2 usual decks and select thru as an input for those.
