In DJay 3, the simple “timed transitions” feature (letting you set fades between turntables at .5 to 15 seconds long) was front and center. I can’t find it anywhere in DJay 4. Is it still there?
Hi Aaron,
The Transition settings have been merged with the Automix settings.
Click on “Automix” at the bottom to change the transition style.
Can you make these timed traditions any longer, they just don’t seem long enough. Thank you in advance!
