Track jumps forward after manual reloop
I have used djay with my idj pro for years and this is something I’ve never understood:
If I use the auto reloop, the song keeps playing from where the loop ends as soon as I disable reloop
If I press one of the 1/2 1 2 1/16 1/8 or 1/4 buttons it loops as long as I keep it pressed but, when I release it, it’s like the song had kept playing on its own; so if I keep the reloop for 10 seconds, 10 seconds of that song will never be played
Is this the expected behaviour?
Hi @Jacopo_Scarpellini,
Thanks for posting this in the Community.
Would you please be so kind and share with all of us a video of the issue occurring? This will help us better understand what exactly is happening on djay.
Hope to hear from you again.
Cheers, G
Thanks, here is a video
You can see that I start the reloop when there are 35 seconds to go to the end of the song, but when I release it, the song has moved forward by the amount I’ve kept the reloop on, so it’s at -24s
It says the video is still uploading…
Captura de pantalla 2021-11-04 a las 9.54.18
Did something go wrong when uploading the file? Could you please check?
Cheers, G
Let’s try with youtube
https://youtube.com/shorts/HwxGuhD_FSM?feature=share
