Hi guys, I’m still using Traktor as my main software. I analyze and adjust my entire music library there. When I use DJ Pro, I grab my playlists and songs from the Traktor import button. But let’s get to the point: there are some songs that, when I try to upload them, I get a message saying they’re not available. They’re black on the playlist. Can you tell me how to fix this?
I checked, but djay doesn’t even appear where you said. I can see rekordbox, I can see traktor, but not djay.
But I don’t understand why I can see all the other files properly.
Furthermore, the files are all in the same COLLECTION folder, inside the MUSIC folder.
All the music files are thrown in there, and from there dragged into the various software programs.
I’ve done all the steps, but unfortunately it doesn’t want to load that track.
However, if I take the same track directly from the original folder, it loads it.
The strange thing is that it doesn’t load it, but it displays all the hotcues perfectly.
And the even stranger thing is that if I right-click that folder, taken from the Traktor link, and import it into my djay collection, it loads the same song.
What it doesn’t do is load it while it’s under the Traktor-Djay link.
Hi, I checked everything just to be sure, but I already knew the answers. The songs are all on my Mac, available on all software, and loaded onto the current main one, Traktor. I’ll make a video for you so you can understand better.
I’ll add that the same playlist taken from Traktor causes the same problem I mentioned earlier.
But if I import the playlist into my collection and go into that specific folder, I can play the same song without any problems.
What if the you check the consistency of your Traktor collection, relocating any missing tracks? This could repair any missing paths that might be corrupted in the nml file.
Or you can also export the collection with a different name and load this new collection file in djay. Make sure that Traktor is closed before using the collection.nml file - the collection file is only updated when closing the app.
Hi, I’ve been very busy and haven’t been able to get to the computer these days, but unfortunately the problem persists and isn’t resolved. The only way to fix it is to import the playlist into my library and get the track from there, rather than from the Traktor link. In that case, it works, as I already showed in the video.
Hi @Screma, sorry for the delayed reply. I have created an Official Support Ticket on your behalf so we can investigate your issue further. Someone from our internal support team will contact you soon via email. To avoid duplication of questions and communication, I will let them take over from here. Thanks!
Hi @Screma, the support team has told me your issue was resolved. They tell me you had a song that contained “//” in the name. After renaming the track in Traktor to remove “//”, relocating it, and exporting the collection again, the issue was resolved.
