Traktor audio 2 and djay pro for Mac compatibility
Will the traktor audio 2 sound card work with djay pro and MacBook? What is the configuration? And will it result in only one stereo channel being sent front of house? Also curious if the USB hub is enough to power the unit or would I need the optional ac adaptor. I also have djay pro for my iPad Air and iPhone 5s. Thanks
I answered this…yes…it will work if you run Traktor
Start tracker and let it scan…minimize it. Start djay and the split outputs on the native instruments audio 2 will function as expected. A workaround I guess. Not sure I want to risk this at a gig. The NI audio 2 does sound wonderful,…is teeny and cost only 69$ and came with Traktor le…hmmmmm?
