Hi
I have created a midi file for Djay pro on my mac an I was wondering if anyone know how to transfer Midi files to the iPad version of Djay?
Hi
It worked for me (with my Faderfox DJ44), but I think only if your controller isn’t already supported on iOS.
The same issue. I’m getting crazy to transfer the modded file to my ipad2, even if I read that it can be simply done adding the file to djay documents under iTunes.
this doesn’t work
any new by your side? thanks in advance
Yeah, I found that IPAD users can load/transfer map files ONLY for unrecognized/not natively supported IOS machines. All the natively recognized HW’s can’t be modified or remapped as Ipad profile. Only on Imac and PRO version this is possible (successfully done !)
Nap nowas hing
Nap nothing
