Are we still not able to transfer our music library to a different iPad? If my iPad quits functioning or if I want to use one for backup is there a dedicated login we can use to duplicate the same playlists either through Apple or login we create through settings? I realize we may have to pay for another subscription but just would like this feature.
- Device model paid air 10 generation
- Version of operating system iOS
- Version of djay *latest 5.3.1
- Hardware/controllers used Hercules Impulse 5””
Hi @Carla_Spence, what music source are you using? Are you using Local Music stored on your iPad or only streaming services? Please provide more details.
Hi, I know the streaming services transfers over, I am speaking of the
playlists that are created using the streaming which is stored in my
collection.
Thanks for clarifying @Carla_Spence. All of your My Collection playlists can easily be transferred from one device to another by copying over the djay Media Library database file. On iOS you can find the database using the Files app in On My iPad>djay>User Data. No other subscriptions are required.
If you are only using streaming services, no other steps are required. However, if you are using Local Music, you will also need to copy your actual mp3 files to the new device as well.
collection.
Yes @Carla_Spence, I explained how to do this already above. Please note, these are the playlist contained in the My Collection music source.
EDIT: I’ve also changed the title of this topic to more accurately reflect your question.
Hallo ik heb djay gekocht voor androit kan ik dit ook gebruiken voor in windows 11
Hoe krijg ik djay op mijn pc
Hello, I bought djay for Android. Can I also use it in Windows 11? How do I get djay on my PC?
Hi @eddy_lem, welcome to the Community! Yes, djay is supported on Windows 11. Simply download it from the official Microsoft Store.
See this linked FAQ for using your single djay Pro subscription cross platform
https://help.algoriddim.com/hc/en-us/articles/12806719766684-Using-Your-djay-Account-Managing-Subscriptions-Cross-Platform-Access-and-Legacy-Support
NOTE: currently there is no way to copy your My Collection playlists between Android and Windows. You will need to recreate these manually on Windows.
Hi, if the music in my collection that i have organized playlists and are streaming services will my playlists transfer over? Imfollowed your instructions and it’s not working. I air dropped it…do i need to transfer another wayto. A differenr IOS. And for a laptop how would i transfer?
Hi @Carla_Spence, I’ve never tried this using AirDrop so I’m not 100% sure if that will work. I uses the Files App and it work every time. Just make sure when you copy the database from one device to the other that you Replace the one in the destination folder. If you make a copy then it will rename the database and it won’t work.
The same process works between iOS and macOS.
